Have noticed my battery losing voltage each night. Scanmaster says charging 13.5-14.5 so it seems the alt. is putting out. Just checked battery and with engine off, it was 12.2 and if I check it every 6 hours or so it drops a few 10ths, although do not recall falling below 12v. When charging the battery and setting on 6A/12v setting goes to almost full scale deflection and takes most of the night to get back to 0.
Had Advance Auto do a charging system check and alt and batt fell in the "Good" range.
Followed the link Gary1970 posted on parasitic drains and had a .25 reading on the 10A setting. Did not go through and pull each fuse to find it, (lazy), but when making the electrical connection with the meter probes, I got the "ding" like when putting key in ign. Which fuse controls this, and is the parasitic drain too high?
The battery is from 2007 and do not want to just throw a new battery at the problem.
Carl
Carl
