How important is the Wastegate Solenoid with an aftermarket turbo and adj. wastegate? my problem is that the stupid prev. owner had the vac lines hooked up wrong. he had the Wastegate Solenoid t'ed in to the PCV and so i fiugured that out and ran them the correct way and as soon as i boosted i heard a loud pop. my car then wanted to boost to 26psi. i found that the Wastegate Solenoid now became a vac leak. so i then did just a compresser to wastegate line and boost psi is normal again. so my question is does the Wastegate Solenoid really matter? thanks in advance.
