does the car smoke ?
if not clean the oil out and keep riding if the car has a tendicy to smoke then it would be about time for a turbo rebuild
also pull the plastic pipe off at the t/b and open the throttle and see if its oily in the t/b if so then it could be sucking oil in the pcv valve.
if you still have the hose from the oil filler to the plastic inlet pipe toss it and plug hole on the pipe and for the filler tube i just put a piece of heater hose on it and ran it down to the frame on mine becase of blowby would get oil all over the motor..
