Wastegate solenoid for 87 GN
I pulled the elbow off and found no oil after a run into town. When I was removing it one of the bolts broke so I am soaking it and am going to ez out it. I will put it back together and try the hose trick. The turbo spins freely with very little side play. I looked in the "Y" fitting but didnt see the orifice I have read about. Not sure if I need one of those also. I plan on getting it back together tomorrow. The "donut" seal is not in the best of shape but I will just put it back in. If the hose trick gets my boost back then I will let you know. I will also try and switch the "Y" fitting around just incase it was put on worng from the engine rebuild. This is just very frustrating:mad: Let me know how much just in case. thanks T
