1987BuickGrandN
- Mar 21, 2002
i've herd people say...
spoolup is affected by wastegate hole size.
why would the wastegate hole size affect spoolup???
if the wasegate is completely closed durring spoolup
and open durring a set manifold pressure (to relieve gas/pressure/decrease or maintain boost)
why would having a hole thats too small affect spoolup??
i could see how having a hole thats too small and not allowing enough gass to pass through/still creating thrust(i.e. boost creeps/manifold pressure still increases)
but...not spoolup
am i correct in this assumption?
also...
if i have an adjustable wastegate
as boost increase.... the wastegate rod will push further out and uniformly/steadily open the wastegate...as boost increases
if this is the case
an ideal situation where the wastegate is completely closed durring spoolup cannot be achieved
hence the need for an electronic boost controller or wastegate silenoid (as implamented in the GN)
i.e. to open the wastegate (all at one time, not incramentially) after spoolup to alleviate excess manifold pressure
but...not spoolup
also...
if this is the case
