So i have looked through out the site to find a little to no information on how to fix this. I was driving the car the other day and it would just randomly die after about 30 mins of driving in 100 degree heat. Popped the hood checked for spark it popped away with the wire off. Moved on thought my maf might have came off still good. Then looked at my fuel pressure gauge and it was down to around 20. so i cracked open the fitting and it just hissed and then some fuel would spurt stop hiss spurt.
I deal with this at the shop i work at, as we build carbs and it sometimes comes up. So i let it sit for a few mins cracked open the fitting to vent pressure. Tightened it up turned it over and my buddy said it went right back up to 40 psi. then ran great. Drove about ten mins and bam again. Same thing. so i got on here seen some dudes having issues with there fuel caps not venting. So i took mine off yet again 20psi did the same thing cracked it open and it started and ran for about another 10 till i got home. The pump is a oe replacement that has only been there for about 300 miles the fuel filter is about a month old. I did smell alot of vapors up by my canister. I don't know if maybe its not venting back to the tank for if i just got te fuel lines to hot an they started to vapor the fuel. If anyone has had this issue before please lend some ideas.
Matt
Matt
