B buckbuick Member Joined Oct 5, 2010 Jan 16, 2012 #3 should i use zddp additive with VR1 or maxlife oil.
G gnloyalty8777 Member Joined Nov 26, 2011 Jan 16, 2012 #5 buckbuick said: should i use zddp additive with VR1 or maxlife oil. Click to expand... I use it with my VR1
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Jan 19, 2012 #7 I use Delo 400 in my flat tappet engines. ~JM~
N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Jan 20, 2012 #9 ~JM~ said: I use Delo 400 in my flat tappet engines. ~JM~ Click to expand... Be aware that diesel oil is made for low RPM use as higher speeds can cause it to foam. Also, the diesel formuation uses more detergent which helps keep residue, and lubricant off cylinder walls. You probably will never see a problem using it on street engines, but I would never use it in a performance build.
J ~JM~ Wrinkled Member Joined Oct 31, 2007 Jan 20, 2012 #10 The Delo oils are spec'ed for gasoline engines also. Last I checked Delo 400 still had the highest zinc content on the market. That has been my main concern. Thanks ~JM~
turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Jan 21, 2012 #11 Look at the circle on the back and if it says SM or SN the zinc content the zddp s low and your flirting with disatster with aggresive grinds and higher spring psi
