valve ping
hoottrod3
I have converted my H-A to 86-87 module and coil now I have bad valve ping under acceleration of any kind and it does not idle right like the timing is real high
yep. refer to your post #3.......
I don't have a chip for it yet but I thought you could swap module and the coil to the 87 with out swapping computer I bought the harness from caspers supposed to be a plug in play and the only reason I swapped it cause the coil was firing real weak I cant even boost right now cause there is so much denotation
I hope this helps
To do the job you need the Coil Pack, ECM, Chip, and MAF. Without a ScanMaster you're not going be able to tune it as well so that is a highly recommended item. These cars can be modified but you have to take advantage of the information out there and make sure you do your research. I found all of this on 2 forums, gnttype.org and turbobuick.com. Don't be shy asking questions but there's a lot of info on the forums that can get you what you need.
Coil Pack upgrade
http://www.gnttype.org/techarea/ecmsensors/ecmpage.html
http://www.gnttype.org/forums/showthread.php?t=5046&highlight=coil pack upgrade
Coil Packs—Type 2 Conversion
1 ea. - Adapter Plate-- GM# 10469468
1 ea. - Ignition Module-- GM# 10456478
3ea. - Coils-- GM# 10472401
Pasted from <http://www.turbobuick.com/forums/threads/late-model-coil-module-upgrade.372525/#post-2971601>
86/87 ECM upgrade
  1. Scanmaster
  2. 86/87 ECM (#1227148)
  3. stock 86/87 GN chip
  4. stock good working 86/87 MAF sensor (LT1 or LS1)
  5. IAT sensor (install and pin in an IAT sensor to pin C11)
http://www.turbobuick.com/forums/threads/basic-hotair-info.33080/page-2
http://www.turbobuick.com/forums/threads/mass-air-flow-sensor.403468/#post-3303786
