Ok so I had the common problem with the Hydroboost failing on my 87 GN and I didnt want to shell out $1200 for a reman unit so I got a brake pedal setup from an 87 Carlo and I bought the vacuum booster and master cylinder new for an 87 Carlo. Problem is the brakes feel a little soft and it wont hold much boost on the line. I did a brake flush and there is no air in the lines however the only vacuum line I could run was a 3/8 hose and I know I need a bigger hose. What have some of you guys done in order to get a good vacuum draw on that booster? A seperate vacuum pump? Electric setup? I know there are not any plugs on my manifold I can draw from so any suggestions would help.
-Andrew
-Andrew
