yea that's about where i'm at going to take a day or two of recovering crawling upside down under the dash isn't my idea of having funWhen I did the hydroboost, I had to unbolt the pedal, hook the eye and then bolt the pedal back on. Vac may be different but it doesnt sound like it.
already had vacuum setup just trying different booster.Stupid question but did you change the pedal assembly? There is a difference between the vacuum and powermaster pedals unless you bought the Kirban booster that has the correct offset on rod.
I've only had glasses for 2 years and bifocals about a year I just use reading glasses when under the dash don't know if i'll ever get use to themmultiple times,
every turbo buick I get, gets a vac brake setup.
and the glasses trick helps alot,
( I had lasic eye surgery , so no more glasses)
