Vac Brakes Intermittent!! Please Help!
What do you think is the cause of the whine in your hydroboost? Air in the ps system?
I dont know. There's no air they've been bled to death and there are no micro bubbles in the reservoir.
I've heard that it's the fluid coming from the PS side and the HB side going into a T fitting before going into the reservoir. I'm hoping a new reservoir with an extra port will cure it.
It's not loud but I find it a little annoying on long trips.
Interesting. I have never seen a stock hydroboost on an 83/84 Turbo Regal. Does that stock setup use a T like we have to when fitting it to an 85+ car?
X2
I've had vac. Brakes for 20 yrs. No problems. Sounds like loss of vacuum. Swap the vacuum block And check All other hoses for leaks. Good luck:cool:
X3. T'd off of the pcv and had the same problem. Went to vac block and problem went away. I think how you tee off of the pcv (top vs side) determines how well it works.
