:biggrin: I just got around to finishing the vacuum brake conversion for my GN. I am very pleased with the results. Since I am definitley keeping the GN, I went with all new/remanufactured parts even though junkyard parts would be much cheaper. (but I did however get the brake pedal from the junkyard)..The powerbooster I bought is the dual diaphragm setup, and I suspect it has much more assist power than a single diaphragm booster.
I am really impressed with the stopping power my new vac set up has, I was a bit skeptical since others have complained about vac set ups on this forum.
If you are looking to do a vac conversion and plan to buy the parts from a Kragen/ NAPA type of auto parts store, I suggest you buy the master cylinder and powerbooster separatley, they can be bought together as a kit together, but it would cost you an extra $60 compared to buying an individual powerbooster and an individual master cylinder and putting the two pieces together yourself. The only difference is you would have to also buy the 2 nuts that holds them together (no big deal).
So with the powerbooster, mastercylinder, used brake pedal, 3 feet of 3/4" vacuum hose, one Kirban's vacuum block with the vac brake inlet, and a large bottle of brake fluid, I spent a grand total of a bit over $200, but I was also able to sell my working powermaster to recover some of the costs The conversion is really straight forward and only basic tools would be needed.
I decided to go vac instead of hydroboost because I think the parts are more universal and will be more readily available and cheaper than hydroboost parts in the future.
