tom robison
ALL UP IN THEM GUTZ
- Dec 11, 2004
Here is a updated list of parts and some new. The number behind the description is the pic number at the link.
2-Stock doghouses 30.00 shipped each (2195)
1- Stock throttle body housing and blade only ,no iac housing 25.00 shipped (2196)
1-Stock throttle body, no iac housing 50.00 shipped (2197)
1-Stock fuel rail, slight bend a regulator 25.00 shipped (2198,2199)
3-Stock fuel rails 30.00 shipped each (2200,2201,2202)
3-Cam sensor bases, 1 broke, 1 needs pined, 1 good, no caps on any 50.00 shipped for all (2205)
2-Sets of stock fuel lines , feed and return 75.00 shipped per set (2206)
2-Stock air cleaner boxes 40.00 shipped
2-Powermasters, 1 complete and 1 for parts condition unknown 100.00 shipped for both (2208)
1-Stock turbo inlet bell 20.00 shipped
2-Pass side valve cover 20.00 shipped each (2210)
2-Sets of stock valve covers 35.00 shipped each (2210)
2-90* bracket, Alt to Header support 15.00 shipped each (2211)
3-Power steering pump 45.00 shipped each (2215)
1- Belt tensioner pulley 20.00 shipped (2216)
1-Stock coil pack bracket 20.00 shipped (2217)
1-Stock shifter 25.00 shipped (2220)
1-Windsheild wiper parts 50.00 shipped for all (2221)
1-Radiator top plate has a dent 40.00 shipped
1-Stock electric cooling fan, wired for high only 40.00 shipped (2210(2))
1- Hooker header downpipe Make Offer (2211(1)
1-Home made downpipe, External pipes have been cut off and dented for frame clearance. 125.00 shipped (2212(1),2213(1), 2214(1))
1-New front chrome alternator cover 50.00 shipped (2216(1)
1-Used manual boost controller 20.00 shipped (2217(1))
2-Used stock alternators for cores 30.00 shipped each (2218(1))
1-Digital Dash Condition unknown 65.00 shipped
1_grey dash surrroung 50.00 shipped
1- sete of headlight bezels w/ marker lights 200.00 shipped
1-NOS upper console piece Blue in color Part# 25520898 160.00 shipped 2219(1))
3-Stock oil pans 50.00 shipped (2222)
Stock Front Covers 25.00 shipped
2-sets of used oil cooler lines 20.00 shipped each (2220(2))
1-Stock crank pulley spacer 20.00 shipped 2221(2))
1-Stock crank pulley spacer w/ pulley 35.00 shipped (2222(1))
1-Turbo oil return line 50.00 shipped (2224)
Stock main caps 25.00 shipped per set (2228)
Oil slingers 5.00 Shipped each (2227)
2-sets stock exhaust manifolds have been fixed 100.00 shipped per set (2220(3))
1-Stock TV cable 40.00 shipped (2221(3))
Stock pushrods and rocker assemblies make offer (2222(2))
1-set stock intercooler brackets 40.00 shipped (2223)
1- Drive side intercooler bracket modded, can be put back to stock easy 25.00shipped (2224(1))
1- new oil pump spacer 15.00 shipped (2226(1))
1- oversized up pipe for stock intercooler 25.00 shipped (2227(1))
1-set front lower frame braces 40.00 shipped (2224(2))
Multiple Dash gauge bezels 35.00 shipped (2225(2))
1-Dash and radio plate carbon fiber 50.00 for the set shipped
Multiple shifter plates 20.00 shipped (2223)
1-Shifter plate w/ 4 speed custom plate for pro stick sifter 30.00 shipped (2224(3))
1-Blue center console complete , driver quality 150.00 shipped (2225(3),2226(3))
1- Gn center console , has been cut up for race car 100.00 shipped (2227(2),2228(1))
Multiple sets of blackout and chrome taillights 75.00-125.00 per set (2229(1))
Qtr glass sets 50.00 per set (2234)
Stock wiring harnesses 150.00-250.00 shipped
2-Underdrive pulleys, Crank and alternator , 40% under drive 65.00 shipped per set (2237)
1-set of used 6.5 off center carrilo rods wide journal 300.00 shipped
1-set of used 6” K-1 Rods 350.00 shipped (2239)
1- New 86-87 Gn emission tubes ¼” and 3/8” Part #bu01013-oe 15.00 shipped (2241)
3- Gm Timing tensioner bolt 5.00 shipped (2245)
1-Set of used 3.820 hypereutectic pistons on reconditioned stock rods 150.00 shipped (2246)
1-Set of used 3.830 10-1 comp forged trw pistons on reconditioned rods 100.00 shipped (2247)
1-Set of Grand national Front and rear seats no tears, need cleaned 400.00 no shipping (2248)
1-Set of t tops 175.00 shipped
1-Set of GM t top seals
1-Grand National Dash Plaque 75.00 shipped
1-Set of Tinted Bumper Lights. 50.00 shipped
1-Fuel pump hanger connecter is cut of 50.00 shipped
These parts are no shipping, must be pick up
1-Set of Grand National Seats 400.00
1-Set of Leir Seigler seats 200.00
1-Set of gn door panels 100.00
1-set of blue door panels 50.00
1-set of doors 400.00
1-set of doors stripped, no crash bar in one 200.00
Fenders 50.00 each
1-set of qtr panels cut from a rust free gn 300.00
1 set of fiber glass bumpers 250.00
If you don't see it, I still might have it just ask .here is the link to pics
Buick Parts pictures from entertainment photos on webshots
Fenders 50.00 each
