UPDATED PARTS LIST - Engine, Trans, Interior, exterior, chassis with Pics.
87 WE2
Open to offers on most parts, unless a price is listed, I am building a hybrid selling off some stuff laying around to help with the cost of parts I still need for the project car.
I uploaded some pics of parts into the thread, see pics of all other parts here: Parts for sale pictures by turbo231 - Photobucket
If you do not see pictures of a part in the link you are interested in please let me know you e-mail address and I will take/send some for you.
Exterior:
Rear bumper impact strip (all black) 8 out of 10 very nice.
GN rear bumper with rust in inside, paint bubbles front rust on outside (pick up only).
Rear bumper support, steel (pick up only)
Front bumper support, steel (pick up only)
Stock fuel door/license plate holder
Trunk latch, with hardware
(2) GN emblems used,
Antenna guide and nut for fender
Quarter panel vents
License plate nylon nuts
Interior:
Door escution trim, chrome missing on end near pull strap
Gray seat belt trim
Cruise control, black control box for under dash (2 each)
Passenger side window switch
Vss buffer, inferred eye missing
Door lock pull up knob
NOS Brake switch for brake lights (NOT POWERMASTER)
Used IGN switch
Gray B pillar trim (pair)
Engine:
Turbo shield cut for 3” downpipe, new triple chrome plating $150
Mint triple chrome plated oil fill tube with cap $75
3" Chrome MAF tube, $50
Exhaust elbow, mildly ported
Complete cam sensor, used working cond
6 Stock injectors
Stock fuel press reg
Fuel rail fuel pressure guage
Stock Cat converter modified to accept 3" DP
Rear coil pack/ign module support bracket
AC lines, driver condition
Good original Ac comp
2” heavy duty intercooler to turbo couplink (2 available) & (1) 2” T clamp
Heater relay
Pass side valve cover spark plug wire holder
2.5” exhaust clamp
2.25” exhaust band clamp brand new
AC line flex tubing
Starter heat shield
Good 2 bar map sensor
3” cutout pipe block off plate with wing nuts and tool
Trans cooler line, short rad side
EGR valve good used
Stock vacuum pod with gasket & bolts
IAC gasket
Stock oil filter adapter nut
T-Stat housing
Good used crank sensor with mount
Stock stat new
Good knock sensor
Delco 02 sensor used good low miles
Used oil pump pickup
Suspension:
2 steel brake drums, painted with silver vht 1500 deg paint
Stock rear swaybar with hardware
Stock lower control arms,
Trans parts:
Misc trans pan bolts
Good used D5 converter $75
2 torque converter inspection cover (one missing a bolt tab, other has cooling holes drilled)
19k mile trans pan with bolts
Trans BQ 200r4
I picked up a motor Sunday 1/18/09 and it came with a transmission that I do not have a need for, I already have a 200r4 built for my project so this trans has to go.
Working BQ 200r4 - No converter $250 obo, with D5 converter $300 obo
Pick up only or I can deliver it for a gas fee up to 50 miles from zip 19014
+ shipping on all parts to 48 states, unless pick only is noted
86/87 Throttlebody - no linkage arm, spring kit, TPS, or IAC Its a bare throttle body with shaft and throttle blade.
Good used timing cover with oil pump (missing timing tab & mech fuel pump block off plate)
Good used water pump, new gasket included
Good used power steering pump (no pulley)
Plastic EGR cover
Turbo oil feed line
Stock plastic vacume pod
Nice used set of door glass dew wipes the interior ones that attatch to the door panel.
Make an offer, all parts have to go. Thanks :)
Turbo sheild - Sold.
GN emblems - Sold
Pass side valve cover spark plug wire holder - Sold
Knock sensor - Sold
