Updated Parts From My Low Mileage '86 T-Type
Greybeard
Buick Grand National 8.5-inch rear. 3.42:1 gear (G80/G87) - Have maintenance/service records. 18,750 original miles. Mint. $850
Buick GN/Monte SS Quick Ratio “YA” code power steering box. Mint. Still has OEM ink stamps visible. 18,750 miles. Perfect for early Camaro/Firebird swap. $250
Buick GN/GM G-Body dropped pitman arm for power steering. Mint. $20
Buick T-Type wheels (1986). Cast aluminum. Mint. 18,750 miles. Includes center caps. $500
Buick GN/T-Type torque converter - $100
Buick GN/T-Type flex plate & hardware - $35
Buick GN/T-Type starter & hardware - $50
Buick GN/T-Type Upper & Lower a-arms, complete with cross shafts, ball joints & bushings. Stock - $120 (for set)
Buick GN/T-Type transmission crossmember & mount – $40
Buick GN/T-Type trailing arms, upper and lower (rear). Stock -- $50
Buick GN/T-Type air conditioning & heater parts package: compressor, drier, condensor, evaporator core, heater core, heater blower & fan, a/c box top cover at firewall – Package price -- $125
Buick GN/T-Type cruise control - $75 each (I have two of these)
Buick T-Type shifter, complete with cable (burgundy handle – absolutely mint) - $75
Buick GN/T-Type power steering pump - $50
Buick GN/T-Type radiator, bare - $150
Buick GN/T-Type electric fan assemblies with shroud – $80
Buick GN/T-Type evaporative emmission system (cannister) - $10
Buick GN/T-Type (stock) fuel pressure regulators X2 (appear NOS) - $25 each
Buick GN/T-Type shock absorbers, front and rear (stock, no leaks) -- $75/set
Buick GN/T-Type K&N PCV style breather, used -- $10
Buick GN/T-Type Spark Plug wires, original set, missing one OEM wire -- $20
Buick GN/T-Type Screen over passenger side cowl -- $10
Buick GN/T-Type Gas tank. Turbo configuration with platistic internal baffles and sump. Very nice condition (near perfect). No leaks. Can’t ship. $150
Buick GN/T-Type Power Master firewall adapter. Can be used to install manual brakes on Buick and other GM G-Bodies. Very nice condition. $20
Buick GN/T-Type/GM G-Body tie rod sleeves. Mint. $10
Kirban GN/T-Type, GM G-body pinion snubber. 3.25-inch tall. Bolts in place of stock snubber. $19
Ultra wheel center caps (steel bullet style) that fit GM T-Type wheels directly. Used. $10/set of four.
Parts are located in Cobble Hill, BC, Canada (West Coast). Thanks in advance...
'Beard
Parts
Any chamce of interior parts?
Looking for drivers side power seat motor.
Also Top dashboard panel where the speakers go.
Hopefully in burgundy.
Home email: theketz@comcast.net
Thank you in advance for your reply.
Jonathan R
Let me know how much for shipping to 47022. Do you take paypal?
TTT ...
Mark Upper & Lower A-Arms, A-C parts, PS Pump, Power Master Adapter Sold. Remove Ultra Caps from list.
Thx...
'Beard
