BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
86/87 parts:
-Stock heater core- $60
-Stock crossover pipe(2) -$ 35 each
-stock intercooler - $80
-turbo heat shield - $30- pending
-3.42 richmond gears - $90
-stock intercooler shroud - $20
-stock inlet bells (2) - $5 each
-stock up pipe - $20
-stock wastegate actuator $15
-turbo bracket $15
-clear parking lenses - $15
-stock posi rear - $800
-stock turbo (core) - $90
-stock front sway bar - $40
-4 stock t-type wheels w/ caps - $275
-Front bumper, no lights oe bezels, fair shape $75
-pair gn lower door panels- $60
-complete engine harness - $250
-4 GN wheels w/ new caps- $300
-2 85 gn wheels with broken center rings (good for slicks) - $100
-stock gn valve covers - $60
-stock downpipe (2) $20 each
-stock fuel pressure regulators (3) $20 each
-2 stock ECM- $75 each
-2 stock turbo cranks - $300 each
-Blower motor- $50
-Flexplates (2) - $35 ea.
-Throttle body and plenum, no arm, spring or iac- $ 125
-Cruise control unit- $ 40
-EGR valve and solenoid- $ 50
-Stock shifter- $ 30
-Right side air dam- $ 25
-Stock intake-shaved .030 - $80
-water pump pulley (2)- $30 each
-Stock fuel sending unit- $30
-Stock 87 Grill- $90
PERFORMANCE PARTS:
-ATR stainless headers for stock style heads- $700- pending
-Champion GN1 Aluminum heads, w/gn1 valve covers, scorpion roller rockers,head stud kit-$1400
-Ported intake W/ 70mm Precision plenum, RJC power plate, 70mm Accufab throttle body, Accufab regulator on modified fuel rail,
EGR block off plate, .- $550- pending
-Pair of 1026 fel-pro head gaskets- $80
-March underdrive pulley kit w/intercooler fan- $120
-B+M line lock- new- $60
-New heated 02 sensor kit- $80
-204/214 speed pro hyd. cam - $75
-.030 speed pro forged pistons - $200
-ECM modded for low impedance injectors- $145- pending
-Extender Xtreme chip for 95's- $90
-95 lb Delphi injectors- $300
-4.10 richmond gears - $125
-B+M torquemaster torque- 2800-3200 stall, th350,th400- $200
-2" to 3" reducer hose-blue- $20
-2.5" to 3" reducer hose-blue- $20
-3" by 3" long intercooler hose- $10
-2.5" by 3" long IC hose- lt. blue-$10
-High pressure adjustable wastegate actuator te series - $60- Pending
-High pressure wastegate actuator-ta series- $60
-Various t-bolt clamps- $10 each
-RJC power steering pump pulley- $50 new!- pending
-RJC water pump pulley- $60- pending
-RJC crank pulley- $120- pending
-RJC Idler pulley- $50- pending
-Lokar trans mount dipstick + tube- $50
-alternator fan- $10
-BRF core transmission- $250
-Moroso trick rear springs w/ airbags- $145
-Pair of mint redone GTA rears- $ 225
-Weld 15x8 prostars, 4.5"backspace, drilled for screws- $200- pending
-Pair of 8.5" vectors, centers painted black, holes drilled for screws- $175
-Pair of 8.5" vectors, good shape, $250
-4 polished center lines- 2 15x7,3.5" bs, radial tires, 2 15x8.5, 4.5" bs, 26x10 slicks.- $800
-Weber Billett roller cam, 218-212, 511,503 lift. 113 lsa.- $275
-Weld 10x15, 5.5 BS w/ 28x 10.5 mt et drags, - $500
-Auto meter 5" tach, w/ shift light, - $90
-New Heavy duty GN 2004r driveshaft, w/yoke, new spicer joints.- $350
-3.5" stub downpipe, 4" long, build your own DP, internal gate. - $200
-Custom oil pickup tube for stage 2 blocks- $95
-Wiseco forged pistons for 4.1, clearanced for stroker- $ make offer
-Rollmaster billet-crank style timing set, 20-25 runs- $75
-Extended 14 bolt oil pan, deepened 1", $125
84/85 PARTS:
-complete intake - $90
-turbo/ throttle body assy. (core) - $80
-engine accessory bracket - $25
-braided down pipe - $20
INTERIOR:
-Grey steering wheel- $45 (rough shape)
-Green Steering wheel- $80
-grey dash pad - $80
-rear quarter window trim - $15 pr.
-3rd brake light - $5 each
-t-top wide front trim - $10
CAR AUDIO:
-Alpine CDM-7861 flip face cd player- $150
-Alpine CDA7863 flip face cd player- $ 190
-MTX thunder4122 2 channel amp- $ 100
-Memphis mono amp 16pr1kd- $ 250
FRESH LONGBLOCK ---10-15 RUNS:
10/10 stock turbo crank
billet center mains
RJC girdle
stock checked + magged turbo rods w/ ARP bolts
.030 forged speed pro pistons, plasma moly rings
comp cams 212-212 hydraulic roller cam + lifters, roller cam button
rollmaster timing set
comp hi-tec pushrods
hi-volume front cover
RJC head gasket kit
Fully race ported iron heads
manley severe duty stainless valves 1.77/1.50
t+d shaft mount roller rockers
comp "beehive" springs, retainers, and locks
cost me over $5000 u.s to build, sell for $4000,(or $4500 with complete intake above) only 10-15 runs on it!!! Ran 10.53 on soft 1.70 60' foot times @ 136mph
Prices do not include shipping, but MAY be a bit negotiable :biggrin:
-turbo bracket $15
-Blower motor- $50
PERFORMANCE PARTS:
84/85 PARTS:
INTERIOR:
CAR AUDIO:
billet center mains
RJC girdle
RJC head gasket kit
