BigBlockOlds
- May 6, 2003
I have done a search on this subject and have found a few threads but none seem to go anywhere as far as what part numbers needed unless your wanting a stock replacement.
Does UB make an upper control arm that will work with the B-Body spindle swap?
If so, what part numbers do I need and what is the going rate?
I was told by someone that they spent around $350 on the UB UCA's and ball joints which I thought was a bit high.
Thanks for the help.
