Two questions
Martin U
1) Can I plug the two ports on the oil filter adapter so I can run the biggie oil filter adapter and the large filters with no cooler for now?
2) Can I get the clips that hold the injectors to the fuel rail at napa, pepboys ect? Seems that when I stored the first 5 I took great care in doing so...not so much on #6.
I'm out detailing it right now, otherwise I would have taken the three hours searching for the answers. so when I get in I should have a answer
Mart
Thanks Mart
Do NOT plug the ports on the oil cooler adapter.
If you want to run a big filter and no oil cooler, get the proper adapter from RJC Racing.:)
Thanks Nick
The reason I asked is because this is for my hot air which I never had an oil cooler. I do have the biggie filter adapter, and from first look I needed the 87 adapter to use it.
I just looked at RJC site. I didn't remember that he made the other fitting,so I will just get that one untill I get a good cooler mounted.
Glad I asked first.
