Race Car Features:
$64,900.00 – Turn Key with Trailer (Includes your choice of paint, plus new fiberglass doors, complete fiberglass front clip.)
$54,900.00 – Turn Key with Trailer, the way it sits now.
Quick Stats – Section 1
Motor Dyno 1350 HP @ 8500 RPM @ 32 PSI (Still more to go)
Chassis Dyno 1050 HP @ 8500 RPM @ 32 PSI (Still more to go)
Car weight 2825
After only 14 runs car has run 8.49 @ 166 MPH @ 25 PSI (Way more to go)
Estimated ET 7.70 or better @ 185 MPH or better, or faster on a bigger tire
Best of Everything
Engine – Section 2
Kenny Duttweiler Built Buick V6
274 cubic inch Stage II On Center
Custom Built Billet Fabrication valve covers
Stage II Indy V6 Heads – Perfectly port matched to intake
T&D Rockers
Buick Stage II On Center Block
LA Specialties Steel Crankshaft? – 3.625 stroke
Comp Cams cam & roller lifters
Custom built Billet Fabrications aluminum oil pan
ARP Hardware
Best of Everything
Transmission – Section 3
Mike’s Transmission Pro Race Powerglide
Dedenbear SFI Case
Upgraded billet input shaft
Billet gears
Pro-Torque racing converter
Best of Everything
Rear End – Section 4
Chris Alston FAB9 Chromoly housing – fully braced
35 spline Tom’s Differential axels
Mark Williams billet 3rd member
3.90 Gears
Induction/Fuel – Section 5
Custom intake manifold – port matched to heads
Ford Motorsport 160 lb. fuel injectors
2 Innovative Turbo 70mm Turbos (Can be upgraded for 200+ more horsepower)
2 Innovative Turbo Pro-Gates
Custom Built Stainless Steel Headers & Components
Custom Built Aluminum Air/Water Intercooler
Custom Built Aluminum Intercooler plumbing
2 Aeromotive A1000 Fuel Pumps
2 Aeromotive Fuel Filters
5 gallon aluminum fuel cell
Best of Everything
Electronics – Section 6
Accel Gen 7 DFI – programmed by Job Spetter
MSD 7AL
Innovative Turbo Boost Controller
2 TurboStart 16 volt batteries
TurboStart 16 Volt Charger
Electric Fan for Radiator
Electric Fan for Transmission Cooler
Electric water pump
Water pump to cycle intercooler water
AM/FM CD Player
Power windows/locks
All lighting works for street car classes
Interior – Section 7
Full powder coated custom sheet metal interior
Full headliner
Fiberglass dash and custom gauge installation
Custom switch panels – one for running car and one for lighting system
B&M Pro-Gate Shifter
Kirkey racing seat & seat cover
Original Buick Grand National steering wheel with quick release adapter
Chassis – NHRA 25.1 Pro Certification to 6.0 – Section 8
Performance Engineering custom chassis
Chromoly chassis - firewall back
Front suspension bolt ons for certain “stock” or “street car” class requirements
Global West Drag Racing upper & lower tubular control arms
Front QA1 Drag Racing adjustable coil over kit
Front wheels – Centerline 15x4
Front Tires – Mickey Thompson 26x4.5 ET Fronts - NEW
Custom Chromoly 4 link rear suspension
Rear QA1 Drag Racing Springs
Rear Koni double adjustable coil-over shocks
Rear wheels – Centerline 15x10
Rear tires – Mickey Thompson 31x14.5 ET Street - NEW
Custom Chromoly wheelie bar
Wilwood brakes all around, biggest available
Easily stops from 165 MPH without the parachute
Best of Everything – Chromoly Everything
Safety – Section 9
NHRA Certified 25.1 Pro Chassis
Funny Car Cage
Crow Products custom window net
Brand New Simpson 5 point Platinum CamLock belt system
Chute Products parachute
Dual Bottle On Board Fire System – One kit for the Driver’s compartment & one kit for Engine compartment
Body – Section 10
87 Buick Regal
All steal with fiberglass hood, deck lid and bumpers
Body is nearly perfect and primed and ready for paint
Extras – Section 11
Heady Duty open trailer
ProStart 16 Volt Charger
Misc. spare parts, gaskets etc.
Notes – Section 12
Best of Everything
This is a straight car, it is perfect. Has the best of everything. If it was painted it would be a show winner. No exaggeration on anything listed. Feel free to check it out and to have anyone else check it out for you, it is beautiful.
I can arrange to have any potential buyers speak to anyone who helped build it. Everyone likes this car and likes to talk about it.
Complete setup is barely used – beware of other cars that are not COMPLETE
No expense spared
Complete turn-key package – add gas and race! REALLY. Nothing else needed. Both times to the track we did not need to do anything except put ice in it, gas in it and charge the batteries. VERY NICE.
Move forces sale.
Call or email for more info, pictures & videos
Patrick 805.432.8009 Call Anytime
Car weight 2825
Best of Everything
Engine – Section 2
T&D Rockers
ARP Hardware
Best of Everything
Dedenbear SFI Case
Billet gears
Best of Everything
3.90 Gears
Best of Everything
MSD 7AL
Electric water pump
AM/FM CD Player
Power windows/locks
Full headliner
Safety – Section 9
Funny Car Cage
Body – Section 10
87 Buick Regal
Extras – Section 11
Notes – Section 12
Best of Everything
No expense spared
Move forces sale.
