M miz Member Joined May 6, 2004 Mar 27, 2013 #1 If left or right blinker is put on light stays solid.One thing I noticed is on both sides one light is alot brighter than other.Left side started working and then went back to solid light.Arrows on dash are solid light also.
turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Mar 27, 2013 #2 Bulb blown and or ground off/bad connection by battery....the few small grounds that are on inner fender. Prob a bulb
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Mar 28, 2013 #4 There are 2 separate flashers. One for hazards and for turn signals. Check your hazards. If they work replace the flasher for the turns. One bulb brighter could be a different bulb or bad ground.
