Turbo Tweak emissions chip results
Warped
No helmet required!
Just passed in Texas with the stock maf installed (translator would not work in the non-GN mode for some reason). Car has 3" cat and functional egr.
15 mph:
HC 61
CO .01
Nox 179
25 mph
HC 31
CO .01
Nox 58
Sweet. That's exactly what my car will have when going thru emissions. Did they even check for the cat?
Sweet. My 86 GN just passed yesterday here in Delaware. We do a two speed idle test here.
My numbers were:
HC (PPM)
Low: 2
High: 0
Limit: 220
CO(%)
Low: 0
High: 0
Limit: 1.20
Car has 50# MSDs with TT alchy chip with open loop idle. Used a stock DP and low mileage cat for this test. All I did was turn the static FP down to 32psi:eek:. It worked. EGR is removed and blocked off.
