shine1stang
- Jan 11, 2010
Ok guys, im turning to you for some advice. As you know there is no aftermarket world for the v6 mustang, esp turbos. So you guys with the v6 turbo experience might be able to help me out.
My set up is the following: 3.83 bore, stock crank, forged eagle rods, wiseco forged pistons 8.8:1 comp, ported stage 2+ heads, comp cams springs (918 gm springs), ss valves 1.86 Intake 1.50 exhaust, comp cam 218/224 .55 lift 112 lobe sep, ported lower, and a cut and weld upper intake. The upper is being swapped out for a sheet metal. The turbo kit has a precision pt61 w .81 exhaust housing, 3inch dp and single 3 inch maxflow muffler. Currently im running 20-21 psi of boost. Running it all thru a c4 and 8.8 rear w 355 gears.
Im looking at a precision 6776 p trim with .81 housing, or possibly a larger turbo. I want to run 15-20 psi of boost. How do you think i will fair with this turbo? What will this turbo max at? I will be adding a inline 255 walbro pump (have a 255 intank), and high imp 80lb injectors. I would really love to run low 10s, with out really changing much else. Dyno numbers arent that important to me. My current tune is extremely safe, 12* total timing, and 11:1 afr, on 93 oct. I mean ya more power better, but i like being one bad ass v6 mustang.
Thanks for any advice!!!!
