Originally posted by 8587GN Where do I get one? dealer,Kirbans,etc,or amI better off getting a braided set up from Summitt? I`m tired of this thing leaking
An inverted flare like on th stock line should not leak if tight, Is the brass block adapter leaking, or the fitting on the turbocharger?
If you wanted to go to AN-4 braided line, you would change the 1/8"-27 pipe nipple fitting in the turbo to a AN-4 male<(961604 steel)
, get a Earl's Inverted 7/16"-24 male inverted flare to AN-4 male(591942) for the brass block adapter, and the length of An-4 line you need plus AN-4 hose ends.
