B BLU Member Joined Mar 26, 2004 May 7, 2005 #1 Any tricks on getting the bolts removed from the turbo cover ? mine seemed to be fused tight
R Red Regal T Senior Member Joined May 24, 2001 May 7, 2005 #2 Get yourself some PB blaster or some other penetrating oil and let it sit for a while before breaking them loose.
B BLU Member Joined Mar 26, 2004 May 7, 2005 #3 I did try that but maybe I didn't let it sit long enough. Thanks
B Be4u IGNITON Joined Sep 24, 2003 May 10, 2005 #4 Start your car and let it run for a while. It seems to me that PBBlaster really kicks in when everythings hot. Also try the tighten b4 you loosen trick. That helps sometimes. Next time use Nickel never-seez.
