I need some guidance on this one.
My GN is a t top car hand has rust in the header under the t tops. It has rust in both quarter panels, both inner and outer rocker panels. I have priced all the sheet metal form Gbody parts. For just a little more money I can buy a rust free hard top body with no interior.
Would it be worth it in the long run to swap to the rust free body hard top car and find all the trim that doesnt match up or go head and fix the t top car? This would be my first venture into the body working realm for the most part.
I am leaning towards just replacing the shell of the car.
The T tops does not sway me one way or the other.
While the car is apart either way I am going to brace the frame at the rear by the springs, clean and paint the frame replace anything that needs to be replaced while it it out. Reseal the motor to help with the oil leaks replace all the AC components. It will be almost a full rebuild on a budget. I would love to have the motor built put it is not in the cards at this point.
Brandon
Brandon
