TTA valve covers & Harland Sharp roller rockers
Scott89TTA
What modifications need to be done to TTA valve covers when running Harland Sharp roller rockers?
Thanks,
Need to remove the inside
Of the drivers value cover
Where the breather mounts
I run 1.70's clear with no issues
pic's please, someone else posted some pics in another thread that didn't seem to have any changes.
Thanks,
What would be nice is a thread on how to adjust them to work properly. Step by step for the newbies who bought them and don't know how to install them
Driver cover
What lifters are u using?
1.64 HS...oops read it wrong on my phone...using Morel's
Motor is assembled and valves/rockers adjusted buy builder Billy Anderson.
OK so remove the baffle on the side of the driver side valve cover. I also have a FWD passenger side "breather" valve cover that also has a hole in the end with a baffle. Do I need to remove the baffle from the end as well?
I made a plug for it but still has the baffle in the end.
It is very close
I would put some Vaseline on the baffle and bolt the cover down the nut centers the cover !
Then pull it back off and see if there is some on the rocker
One I had to cut out and one I did not. Worth a few minutes of your time to ck
