TT wide band chip question
0-60n4
I currently have the following chip:
T5.6 3665
60# street 93
20/18 degrees 15-17 psi
And using the stock narrow band O2 sensor. I purchased an Inovate Wide Band O2 sensor and gauge and was first thinking about installing it in a separate bung and just using it for a/f readout. But then I saw TT has a wide band chip now. Seems that would be the way to go. Correct?
What is required to connect the Inovate sensor to the ecm to use with the WB chip? Use the original O2 bung or do I have to install an extra bung?
You would still need a 2nd bung, as the chip still uses the stock O2 for all the low end driveability stuff.
You also need a Powerlogger in order to use the wideband 6.1 chip.
