L LOLGN Member Joined Jan 11, 2008 Apr 8, 2008 #1 I ordered a tt chip last week and neglected to ask what thermostat I should run. Everyone runs the 160, should I get that before installing the chip?
87granny Active Member Joined May 17, 2005 Apr 8, 2008 #2 I would call Eric and see what he set the chip for instead of guessing that he set it for 160 just to be sure
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Apr 8, 2008 #3 The chip is set up for a 160 stat. You can run the chip without it, but performance may suffer a little bit.
L LOLGN Member Joined Jan 11, 2008 Apr 8, 2008 #4 Thanks Eric, that's the answer I was looking for :smile:
B bluehair Member Joined Apr 22, 2005 Apr 9, 2008 #5 are all your chips set up for 160 standard? if so i need to check mine...
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Apr 9, 2008 #6 Yes, they're all set up that way. Eric
