HotAir6 v.2.0
Uncool Misfit
- Sep 8, 2013
I'm replacing my transmission cooling lines with new Stainless Steel lines and am having trouble getting the line to seal. I purchased stock replacements with flared fittings. I have looked at the flare and the fitting and both look to be in good shape.
I have scoured the forums and the search function was unable to turn up anything that answered my questions.
1) How to get the flared fitting to seal?
- I know the line needs to come in pretty straight to the port. I can see it's a little off but can't seem to get it to stay straight once I start to install it.
2) Other options for making the connections to the transmission and cooler?
- The line I pulled off had the flare removed and some rubber hose with attached to a fitting with a barb and some some hose clamps. It didn't leak so I'll resort back to this if needed.
3) Has anyone replaced the hard tubing with a hose?
- I think this would be the best way to replace the line. If someone has done this I'd like to know the length used and any other info you have.
Any input will be helpful. Thank you
