I have a built 200 and it wines when I put it in reverse. Running with 3,400 stall. Wines mostly when it's warmed up. Not when cold. It shifts great, up and down, no slip, etc. Just the wine in reverse that I'm concerned about. I changed the fluid and filter and made sure the o-ring is on there. It's been doing it for a while. Cable is adjusted correctly. I have a rather small trans cooler on there now that I'm upgrading. Aux cooler only, not through radiator. Hopefully that helps. No temp gauge yet, so can't tell what it's running it.
BTW, it did it before and after trans flush and filter change. I changed to John Deer fluid to tighten up the converter a bit, which worked.
Can high temp cause it? Obviously it's triggering/causing it.
Or, high or low pressure?
Since it's been doing it for a while, did this cause any damage?
If so, what to look for?
Like I said, trans acts great. It's pretty fretty fresh with all CK internals, etc... Just want to know what I'm possibly in for before I might take it to Jimmy's for a refresh. Like I said, hopefully the larger cooler will solve it. Planning on getting a 10x15 or larger Hayden tube&fin cooler which CK recommended. Thanks for the input.
