TURBORUSTY
- Jul 20, 2006
the car is a 95' cadillac fleetwood brougham with 125k miles on the body and engine.car has a 260hp LT1 powerplant with these mods:52mm t/b,re-programmed pcm(pcmforless),1.6 rockers,accel 9000 cables,brand new opti spark complete,edelbrock billet double roller timing chain,meziere heavy duty electric water pump,hooker longtubes,earls replaceable header gaskets,complete 2.5" exhaust system dumped right after axle w/magnaflow muffs.pro-built 4l60e with about 8k miles on it,vette servo,energy suspension mount,yukon deep pan,4000 9.5" Stall,brand new Eaton Posi unit 800lbs springs,Strange gears 4.56's,chrome diff cover,new axle bearings,d/s balanced to 4000 rpm's by local d/s shop, KYB front shocks,Comp Eng 3way adjustable rears,H&R front & rear springs about a 4-5 inch drop from factory,front brakes rotors pads and calipersoem equip,walbro intank f/p,auto meter vaccum guage with pod, brand new optima RED battery, ALSO SCANMASTER LT1.engine is also dressed up with corvette lt4 composite valve covers and vette fuel rail covers.
i had also added a EXTERNAL P/S,TRANS,OIL COOLERS all from a police application caprice.it has 9c1 rear sway bar and 32mm front 78-80 swaybar with energy suspension bushings.car has no emissions componets on it.
car is black on the exterior with a blue front clip ,black leather interior small tear on drive side seat,PW,PL,TILT ICE COLD A/C .it has a black rag top from factory this was an EX-funeral car R1P SPID CODE.
so for a good portion of its life it was serviced in funeral proccesions.before i got my hands on it.
it will come with black police 9c1 wheels with brand new 235/60/15 tires on them with center caps.
it has a panosonic cd player along with all 4 speakers have been upgraded & 4 tweeters where added power antenna still works up and down as well as the power seat and heated seats, and power mirrors.
car has no major dents just several small dings, all chrome is on bottom 1/4's of the car,missing plastic trims on each corner of the front bumper $15 each on ebay, also rear plastic long strip is broken on one corner.car has no rust on frame,floor or 1/4's of the car this car was a down south car with cery little wear the steering wheel is still intact.
this car has clocked consistent 13.7 and 13.8 @ 98mph 1.8 60' passes on a d/r in hot weather very sticky hot weather on pump gas driven to the track and back home with the a/c on in a lazy boy type recliner seat gets no better all you need is beer and a woman and youre set.
all this car needs is a paint job as i said complete front clip is blue from fenders forward it had a smal fender bender up front and i decided to change it all to one color and 1 of the fenders had many dents prior to altercation.vinyl top is in great condition with no tears.
looking to get $7000 o.b.o. or trade str8 up for a 86-87 turbo -t or GN
