I converted my 84 GN to the 87 setup. The complete 84 engine bay came out, and was replaced by an 87 setup. I have a LOT left from the 84 setup, and I would LOVE to trade ALL that is left for 3 tickets(probably someone with a lot of frequent flier miles) roundtrip from Indy to Miami. If not, this stuff is still for sale.
84 block
rods-pistons-cam(stock)
bracket on pass. side fender w/MAP sensor, fuel pump relay, and the other relay(cant remember what it is)
stock push rods
A big bag of bolts off of the engine(not ALL of the bolts, but a good amount of them)
stock mains
84 ecm
84 wiring harness
stock heads
acc bracket
stock welded 84 headers
stock up pipe
84 heater core
power steering pump
throttle cable bracket
ignition coil bracket
positive battery cable
cam sensor
stock starter
hood turbo heat shield
84 fuel line(from fuel filter to frame)
84 fuel line(from fuel filter to engine)
stock timing chain with timing chain pulley
ground battery cable
cam button
stock crank sensor
stock knock sensor
84 stock water cooling lines(on engine-hard water lines)
84 engine shield(water cooling lines were under, or close to this, can't remember)
84 throttle body(has a little sticky stuff on outside from bad ign. module. (Still moves freely and comes with both sensors and vacuum block)
84 stock cooling fan
84 stock hard vacuum lines(on engine)
84 stock black curved intake tube
84 MAF sensor
stock crossover pipe
84 turbo oil drain back tube
84 belt pulley(went on crank)
84 water pump(I'm not sure if these should spin freely when you spin them by hand, or if it should be a slight bit stiff. This one you spin it, and it doesnt spin freely. I BELIEVE this is the way they should be.)
84 transmission dipstick tube
old extra motor mounts
-A couple other things I have that are seperate-
87 turbo bracket(has one broken off bolt in it)
2 1/4 ton engine lift.
Im trying to trade EVERYTHING except for the engine lift for some airline tickets. If you want something in particular, let me know.
84 block
stock push rods
stock mains
84 ecm
84 wiring harness
stock heads
acc bracket
stock up pipe
84 heater core
power steering pump
cam sensor
stock starter
cam button
stock crank sensor
stock knock sensor
84 MAF sensor
