code 16 is cam sensor signal lost, it means that the engine was running and the unit didn't see a cam sensor for few revolutions.
usually when this happens (cam sensor failure) the engine will keep running but will not restart after you shut it down.
at the very least, you probably have an intermittent cam sensor, or a loose/weak connector in that circuit.
Bob
