Caspers TPS Tech for sale. In the center a small piece of plastic cracked off see pic, does not harm function, was like this when I bought it. Works good.
I copied this off casters electronics website
Plug-And-Play unit inserts between your TPS sensor and TPS wiring. It has two functions; one, it allows you to calibrate the idle voltage of the TPS, and 2, assures full Power Enrichment at WOT. Locks into full TPS voltage at 70% throttle. Maintains consistent TPS voltage at all times, compensates for TPS element wear. LED display indicates functions.
