8 87gnttop1 Member Joined Jun 21, 2010 Jan 24, 2012 #3 The volt meter I have a scanmaster just havent connected it yet
N nitron Member Joined Mar 20, 2011 Jan 24, 2012 #4 You have to do it with the engine off ignition on. Don't do it with engine running
8 87gnttop1 Member Joined Jun 21, 2010 Jan 24, 2012 #5 I was doing it with the engine off it just won't read
J jarredsoon Member Joined Aug 9, 2007 Jan 25, 2012 #6 Way easier with the scan master and a friend in the car while you move the tps. Friend can read ou the number and step on the gas for you.
T turbojd Well-Known Member Joined Dec 27, 2005 Jan 25, 2012 #8 Hook your scanmaster up, it'll make it easier to set the tps, this might help you also, TPS Adjustment
