tools for sale
TurboTA3.8
You wont keep up the pace
Snap-On 1/2 inch torque wrench QD3R250 , Adj. Click-type, U.S., Fixed-Ratchet, 50-250 ft. lb., 1/2" drive $200.00
Snap-On Pliers Set, Snap Ring, 4 pcs. SRP400 $120.00
crane cams valve spring tool 99472-1 $80.00
moroso pro degree wheel 18" 62191 $30.00
electric ring filer proform 66765 $170.00
arp rod bolt stretch guage 100-9941 $100.00
kd ring compression pliers for 3 7/8-4 1/8 boreKD 1123 KD 1114 $30.00
KD pulley remover installer
Remove pressed-on alternator and power steering pulleys on late-model GM, Ford and Chrysler engines. The threaded end installs late-model GM alternator and power steering pulleys, including Quad 4. Reverse the jaws to pull the alternator internal bearing. The puller fits some AMCs KD 2897
snap on Gauge, Cylinder Bore (2.125" to 7" Range) dial indicator 130.00
older model does not have plastic case comes in a box from snap-on
4 PC STUD REMOVER METRIC SET
• Three internal rollers grip the stud securely in either direction for quick and easy removal and installation.
• Designed for hard to reach studs.
• Includes 3/8" drive 6mm and 8mm stud removers with 3/4" external hex for use with 3/8" drive tools or 3/4" wrench.
• Also includes 1/2" drive 10mm and 12mm stud removers with 7/8" external hex for use with 1/2" drive tools or 7/8" wrench.
• All four sockets packaged in a convenient blow molded case.
sr102 $50.00
OEM 11 - Piece Disc Brake Tool Set
Assists in the replacement of brake pads on most 4 wheel disc brake cars.
Forces the pin straight back into the caliper as well as rotating the pistons back in on the vehilcles with self-adjusting parking brakes.Comes in blow molded plastic carry case.
$25.00
oil pressure sender socket for ls1 $10.00
ti2135 IR 1/2 impact gun $150.00
Craftsman 3/8 in. Impact gun
Sears item #00919916000 Mfr. model #19916
One hand operation with forward and reverse push buttons. 260 ft. lb. reverse torque. 230 ft. lb. forward torque. 1,500 blows per minute. 14,500 rpm free speed $100.00
all prices do not include shipping
Looking for cost on K&D install/remover
The puller set did not have a price w/it. How much is it, and how much shipping to 15642. If resonable I will most likely take. Also are these tools new or used? Are the pictures of the actual tool that you are selling, or how they where when you bought them?
DAve
How We Coming Along?
Just wondering.
PM'd but didn't get a reply.
Rich
Arrived Today
older model does not have plastic case comes in a box from snap-on Sold
moroso pro degree wheel 18" 62191 $30.00 Sold
Rich
