Its all a matter of if your chip burner has spent some time to setup some decent values in the chip for 3rd and/or 4th control. I burn chips for myself and could do it depending on your chip and of course if you could live w/o it for a little while. I did one for a friend and he likes it very much. But if your interested we could discuss.
A little more explanation: With GM's values, if your in 4th w/ the tc locked, doesn't matter what MPH your at there's no way to get the tc to unlock w/o the car downshifting to 3rd which usually causes about 10 psi of boost to be spooled up and a pretty aggressive take off by the car. Well, sometimes you don't want all that. So with the application of correct chip values, now as you approach 1/2 throttle, the tc unlocks, you stay in 4th, 5 to 7 psi comes in with no knock and your right back up to speed w/o all the 3rd gear/10psi/rapid blast you didn't want anyway.
