I sold my Twin Turbo GN and now I have these parts left over that were not included with sale of the car.
These parts are all fresh and have been used only a couple of times. They work well and are as close to new as you can get.
You can see pics of this car with the parts listed below for sale on, mgnta.com. Click on member’s rides and then Tom.
Dual pump, SX fuel system, complete. Includes 2 pumps with fused and relayed wiring, 2 check valves, 3 filters, the mounting plate, all of the lines. The feed lines from the cell’s (Not included, See note) dual -10 outlets to the pre filters. The lines from the pumps come from the check valves -8 to a Y-block then – 8 to the final filter and up to the fuel rail. Return line is – 8 All lines and fitings are Earls and Russle steel braided. All fittings and lines included. Retail around $1500. I’ll take ½.
(Note), I left the original cell in the car when sold. I do have a 3 gallon Jaz fuel cell with new mount brackets. It has -8 fittings. The cell and mount kit retail for around 150. I’ll take 1/2, if purchased with the system.
T.H.-400 trans fresh with receipts, Fresh Art Carr converter 3500 stall, B&M Pro stick shifter w lockout, Trans shield, Flywheel shield, Lokar flex dip tube & stick, SeaTrab cooler and lines. Retail around 2000. I’ll take ½.
Wheels and tires. 4 Weld Aluma-Stars with new tires. Front-runners are, the heavier duty multi-ply, DOT, Micky, 26 x 7.50 x 15. Rears are, M&H, drag radials, 325 / 50 x 15. Tires are brand new with receipts. Wheels have been recently reconditioned, ( new bolts ) and polished. Wheels list for around 350 each, Tires were around 600. I have receipts. Retail cost around 2000. I’ll take ½.
Twin Turbo set – up. Includes the 2, 60 compressor turbos with small turbine housings, (also included are larger housings, separate), fresh from Limit engineering. 2 new tial gates, hooker headers old but rebuilt, Duttweiler dual front mount IC and piping. New air K&N air filters for directly on turbo and old K&N air filters with duct tubing for remote air intake. Retail around 3000. I’ll take ½.
Contact me at my home phone, 9a to 9p. 952-892-5669. E-Mail, ttshea@frontiernet.net.
