Reapersgbodys
- Apr 25, 2017
Like everyone has stated, all the plate does is help distribute the airflow more evenly going to the cylinders, I've noticed no "driveability" gains or losses, it has allowed me to run my car for what the chip was burned for with no knock retard. without it, I had KR, its only 1/8" thick ,and I used the same bolts. Also, it upped my MPG slightly, in my case, I chased Knock Retard for months, installed the plate, Knock Retard went away.So bottom line in a mild build would the power plate make a noticeable difference in driveability or performance by the seat of your pants. Also should you use longer bolts to compensate for the extra space used by the power plate. I don't care about the $50 bucks or so but don't want to do something that isn't really going to help. If it's not broke, don't fix it!
