F ffej Member Joined Apr 29, 2006 Apr 9, 2009 #1 ive got a chance to pick up a set of like new tires 235/65/15 and was just wandering how these fit on stock gn rims and if they look ok thanks,jeff
T theCATman Is that a Monte Carlo? Joined Mar 4, 2009 Apr 9, 2009 #2 Stockers are 215/65/15. The ones you're looking at are 20mm taller. They would probably look tall & skinny. Not the look I'd want.
N NVRL8 Huge Member Joined Oct 27, 2006 Apr 9, 2009 #3 215/65/15 is stock tire size = 26 in tall. 235/65/15 is a 27 in tall tire. They'll fit on stock GN rims. Might be a little rubbing up front on sharp turns. Speedo will read a couple MPH slower than actual speed.
T Topjimmy Member Joined May 24, 2001 Apr 9, 2009 #4 215/65R15 was the stock tire size and is 26" in diameter... 235/65R15 is 27.1"... Taller sidewall and wider cross-section than stock by @ 1". Yes they will fit your 7" wheel. -Jimmy EDIT: What They Said!
