Ok people.
Have a issue with pulling on a vehicle, no accidents etc.
Four wheel alignment has been done at two different locations.
Both locations say the alignment is correct.
Car still pulls to the right ! !
The last place swapped the tires front from left to right. ( Directional tires)
This corrected the pulling issue (not sure what this does to the tires).
The tires are BF Goodrich Traction Advantage.
The tire shop tells me there is nothing wrong with the tires . . .
ok now is where it gets silly the one place said the strut bearings were bad; ok so replace the bearings (yes they were bad) at the same time the springs and struts were replaced. ( might as well it is all apart)
Car still pulls to the right. I am going to another tire shop to have them pull the tires and swap them to tell me whether the issue is the tires.
Any suggestions?
Later AJ
Any suggestions?
Later AJ
