L Larry New Member Joined May 27, 2001 Jun 15, 2005 #1 What is the tread size at point where oil return from Turbo goes back into front of block? Thanks Larry
P PaulRV6 Active Member Joined May 25, 2001 Jun 15, 2005 #2 Larry, it is either a 1/2" NPT or 3/4" NPT. Can't remember which, darn mind. The fitting is a 3/4" OD inverted tubing flare on the other end of the pipe thread. paul
4 49-blues Active Member Joined May 30, 2001 Jun 15, 2005 #3 The opening in the block is a 1/2" npt thread-the tubing is alittle larger like 3/4".
