I don't really miss the automatic shifting of the 200 in both my cars with 400s. The T Type rarely sees street duty so it doesn't matter anyway. In my clone I have the same B&M Quicksilver shifter pacecarta has. It makes it a lot easier shifting on the street and it becomes second nature. For the track, I prefer the Hurst QuarterStick thats in the T as I like the gated shifts but I do have to pull a lever to go to 3rd gear. With the Quicksilver you have to release the shifter between each gear and let it go back to a neutral position before you go to the next gear. The Quicksilver is more of a slapper shifter whereas the QuarterStick is good when you like to hold the shifter tight the whole time.
As far as cost, I don't think that is a complaint most TH400 users have, especially if you want an electric transbrake. Just looking on the Extreme Automatics website for a low 10sec trans..... A TH400 with a transbrake good to 1200HP runs about $1800. A 2004R with an electric transbrake good to 750HP will run $2500 using your BRF trans as a core. You should upgrade the driveshaft and yokes once you go transbrake anyway whether its a 200 or a 400. The price for a topnotch PTC converter I think is about the same for a 200 or 400. If you buy the TH400 you can also sell your 2004R to get some money back. You'd probably save $1500 going with a 400 over a 200 and have a stronger trans. If you go used, the 400 is even cheaper. I did that on my clone and only have $1200 in the trans and converter and they would last until the 8s. Plus I'm not worried about having a local tranny guy touch a TH400.
Not having overdrive does stink though. Not having money from all the dough I spent on 2004Rs stunk worse though.
