I have been modifying a generic 200-4R governor I bought off eBay to make it like the one I removed from a MCSS 200-4R as a side project. I took measurements using a triple beam gram scale with a dial indicator accurate to 1/10th gram. Here is what I have at this point:
Monte SS governor:
Large Weight (Slightly modified): 37.2 grams (stamped B 4)
Small Weight (Stock): 14.9 grams (stamped D 5)
Gear: Green 14 tooth / 10 tooth
Light blue spring on small weight
Generic governor:
Large Weight (Modified): 36.7g (stamped A 5)
Small Weight (Modified): 14.8g (stamped C 2)
Gear: Biege 14 tooth / 13 tooth
Heavy spring with 4 coils removed on small weight
I modified the governors by removing material using a Dremel tool with a cutoff wheel. Then the rough edges were filed and cleaned up using a wire wheel.
I have not yet done the set screw mod, but that is the next step. From what I understand, this consists of drilling and tapping the small weight for a set screw to retain the spring on the small weight. The set screw should be loctited in and protrudes inside the coils of the small spring to hold it in place. Is this correct?
After searching prior msgs on the forum, I have seen where others have used the lighter spring (some with coils removed) of the two from the generic governor on the small weight of the modified governor. After comparing the two springs on the generic governor to the "light blue spring" on the MCSS small weight, it seems that the lighter spring is quite wimpy and does not apply the same force to the small weight as the light blue spring does. I ended up using the heavier spring with 4 coils removed, it seems to be more like the force applied by the light blue spring. If anyone has used the heavy spring here, I would like to hear about it...
Perhaps I can use a "torque watch" to measure the force exerted by the light blue spring against the small weight and then try to match that force by playing with various springs.
Anyways I thought I would post info in case it might help someone else out in the future.
Monte SS governor:
Generic governor:
