I have a newly rebuild TH350 with a Hipster transbrake installed. The problem I am having is the trans appears to be stuck in brake mode even with power completely disconnected from the solenoid. I have a solid park , then reverse, then reverse, brake, second and direct. No neutral and reverse is always engaged. Obviously it is a mechanical issue but what? I have yet to get it on the lift but is there anything obvious I should look for? I plan on pulling the solenoid out and test it for function and then peak inside the VB at the valve to see if it may be stuck. Other than that I have no idea where to look. VB gasket? Drum not releasing? Help?
