83 carb/turbo t type
The original TPS sensor had a broken plunger that just fell aprt. I replaced it with a new one. Upon testing it it reads .77 per spec, but the voltage reading actually goes down as the throttle is opened to zero and stays there. Shouldn't it go up? Top wire has 5 volt reference voltage coming through and bottom wire shows continuity to ground. I used middle and bottom wire to check voltage readings using 2 volt scale on DVM. Sounds wrong to me and car stumbles bad upon full throttle from idle.
I ordered another one today, but it came in broken just like the one I removed. it even had "defective" written on the side of the box! hopefully another will arrive tomorrow and I will check it before installing in the carb. I bought the cheap $15 tru-tech Standard brand part the first time, am trying the $50 AC Delco part this time, if I can get one not broken.
