Test pipe
bigballsbilly
I have a 3" RJC downpipe and a Pypes 2 1/2" exhaust. Do I need a test pipe that reduces from 3" to 2 1/2"? All I see advertised is either a 2.5" test pipe or a 3" test pipe.
The test pipe should bolt up to the cat back system.id go with whatever size your downpipe is.
Sent from my SM-G920T using Tapatalk
Nope the 4 bolt flange will mate together. No Adapter needed.
Ok gotcha, I didn't know if 3" of exhaust suddenly going through a 2.5 inch hole with no gradual slope would cause turbulence, but I guess not.
Thanks for the help.
The flanges will match up but inside there might be some deflection. There should be no issue with performance
