D DorianL Member Joined Jun 7, 2002 Aug 12, 2008 #1 Hi, I want wire in a permanent temp and pressure gauge. Two questions: - What NPT is the tap? 1/4? - What should the temp range be for the sending unit that I am going to tap into the PTS deep pan. Thanks! I.
S SSedan64 JoaTMoN Joined Dec 8, 2007 Aug 12, 2008 #2 DorianL said: Hi, I want wire in a permanent temp and pressure gauge. Two questions: - What NPT is the tap? 1/4? - What should the temp range be for the sending unit that I am going to tap into the PTS deep pan. Thanks! I. Click to expand... Some senders use 1/8" some use 1/4". The sender must match the guages needle sweep range. Usually easier to buy a guage with the sender included. Here's one fairly cheap & they have several styles to choose from> REVERSED WHITE 7 COLOR TRANS TEMPERATURE GAUGE - eBay (item 350085015983 end time Aug-31-08 07:05:37 PDT)
D DorianL Member Joined Jun 7, 2002 Aug 13, 2008 #3 SSedan64 said: Some senders use 1/8" some use 1/4". The sender must match the guages needle sweep range. Usually easier to buy a guage with the sender included. Here's one fairly cheap & they have several styles to choose from> REVERSED WHITE 7 COLOR TRANS TEMPERATURE GAUGE - eBay (item 350085015983 end time Aug-31-08 07:05:37 PDT) Click to expand... Makes absolute sense... Say - that pressure port on the side of the trans, what NPT is that 1/4?
M mikestertwo Well-Known Member Joined Sep 13, 2006 Aug 13, 2008 #4 DorianL said: Makes absolute sense... Say - that pressure port on the side of the trans, what NPT is that 1/4? Click to expand... 1/8 NPT
D DorianL Member Joined Jun 7, 2002 Aug 19, 2008 #5 mikestertwo said: 1/8 NPT Click to expand... Thaaaaaanks!
