TE45A turbo
dvernst
TE45A turbo with low miles. Has Garrett .82 exhaust housing. Zero play. Has under 500 miles on turbo, and literally never been boosted over 15 psi. $500
It was installed by SE Turbo. I have a receipt for it from them. That's the only info I have on it
Thanks Dave only reason I'm asking is that there a lot of variations of that turbo .. all depends on who made it ...
is it a 63mm compressor or 66 mm ? ... is it a big shaft turbo ?
Honestly I don't have the answer to any of those questions. Only info I have is it says te45A on the paperwork I have. I haven't measured anything on it. Are you still in Illinois?
Gotcha .. yeah if its a large shaft 66mm TE45A that is one hell of a turbo .. They make stupid power and pull like Freight trains on mild setups.. Luv that turbo ..
Should sell REAL QUICK if its a 66 / large shaft
in IL 1 week out of the month ..
If I take the exhaust housing off, and post pics. Will you be able to identify it?
Here's some measurements
I am interested in the turbo, please call me to discuss a deal, thanks - 602-866-9908.
Im running 10.27 @ 133 with 29 #s of boost. Car is 3850 with driver. The 45a performs well.
Thank you. I'm kind of confused though. Is there more than one turbo considered a TE45A?
A TE-45 is a 66mm vs. a TE-45A which is a 63mm.
Unless you use a machined stock turbo Garrett A/R 63 exhaust housing, a TE-45A is a "lazy dog" when spooling.
A TE45A with a Garrett with a stock exhaust housing and the correct torque converter will spool as good as a comparable BB turbo which is twice the price!
I think John Craig built mine will have to remove housing and check...Wish I had 1st hand knowledge of how mine runs to share but never been to the track with car
