G getchasum MISSING 2 CYLINDERS??? Joined May 23, 2002 Jan 19, 2014 #1 Is ACDelco 10478101 the correct part number for the TCC or will it work as a replacement
J Janis Transmission Member Joined Jan 11, 2014 Jan 21, 2014 #2 just get a fitzall universal solenoid for 2004r ; 700r4 at your local trans shop thats what i use
G getchasum MISSING 2 CYLINDERS??? Joined May 23, 2002 Jan 22, 2014 #3 Thanks.... Question about the one mentioned above. Does it plug straight in or does the wires ends have to cut?
G getchasum MISSING 2 CYLINDERS??? Joined May 23, 2002 Jan 23, 2014 #5 That's what I thought, I really didn't want to cut and splice.
626gn Well-Known Member Joined Feb 15, 2009 Jan 24, 2014 #6 As far as I know (I've looked), a plug n play replacement does not exist unless you can find an original one.
G getchasum MISSING 2 CYLINDERS??? Joined May 23, 2002 Jan 24, 2014 #7 Exactly why I wanted to know the Pt#.....
S stovebolt 34 Member Joined Mar 9, 2012 Jan 24, 2014 #8 Sad to say but , OEM stuff is drying up . Some stuff is not even repo' d . Vendors on this forum and board members are your best bet .
